ProjeQtOr free project management software - Activity to Milestone copy issue - ProjeQtOr
29 May 2019 17:07 - 30 May 2019 14:05 #1 by karl.binet
V8.0.3
When i copy an activity to a milestone, the validated cost follows form the activity into the milestone, if i'm right, there should not be any amount in a milestone.
Is this a normal behavior ?
Now, in global planning, we are stuck with milestone that have a validated cost.
How can i get rid of the amount in the validated cost column.
I'm able to delete the amount in the validated cost column from the planningelement table directly into the database, but i don't know if it's the right way to do it or if it will impact somethings else.
If i create a milestone without using the copy feature, there is no amount in global planning.
Can you help,
Last edit: 30 May 2019 14:05 by karl.binet.
30 May 2019 08:49 #2 by babynus
This is an issue.
Ticket #4030 recorded.
We'll think about fixing wrong existing data while fixing the issue.
(updating data in the table is not a good idea, as change won't be consolidated up to parents)
