ProjeQtOr free project management software - Slow actions on Projeqtor - ProjeQtOr
23 May 2019 09:29 #1 by Yannobi
Since P 7.4.3, i had problems of creation of activities on P. They are way to long. I saw it was an knowed issue and i updated to 7.4.4. It's much better but i still have problem like this :
- Impossible to change the ordre of projects on global planning
- some activities cannot be delete
The loader keep turning and nothing happen.
I see this on logs :
[Thu May 23 08:58:10.353605 2019] [:error] [pid 12540] [client 55.77.122.15:63477] PHP Fatal error: Maximum execution time of 160 seconds exceeded in /var/www/html/projeqtor/model/persistence/Sql.php on line 92, referer: l113301siepqtor.fr/view/main.php
At first sight, i t seems that the server is not enough performant. It is not true : 2 vCPU, 4 Go RAM.
Is it possible to elevate the level of debug somewhere to have more information on the problem and where to search ?
Thank you
24 May 2019 00:08 #2 by babynus
Replied by babynus on topic Slow actions on Projeqtor
You can change logLevel to 3 or 4.
You can also set debugQuery to trace all calls to db
28 May 2019 09:28 - 28 May 2019 15:07 #3 by Yannobi
Replied by Yannobi on topic Slow actions on Projeqtor
Migration from php5.4 to php7.2 + upgrade to Projeqtor 8.0.4 have done the job.
Last edit: 28 May 2019 15:07 by Yannobi.
