ProjeQtOr free project management software - SQLSTATE[HY000] [1045] Access denied for user 'admin'@'localhost' (using passwor - ProjeQtOr
16 May 2019 16:35 #1 by rvasighi
I have an message like below, before i used projector and i solved this problem, but i forgot: i remember for this problem i must chane the attribution file from read only to read and write
but i forgot which file
please help me to solve this issue:
SQLSTATE[HY000] [1045] Access denied for user 'root'@'localhost' (using password: YES)
dsn = mysql:host=127.0.0.1;port=3306
17 May 2019 13:26 #2 by babynus
This issue is in parameters.php (location defined in /tool/parametersLocation.php)
It seems DB password is incorrect.
17 May 2019 13:44 #3 by rvasighi
Thanks for your quick answer, but my problem is exactly that i have not parameterlocation.php
i have not this file
i check in tool liberary and i didnot find it. last time when i contatct to projeqtor they told me this a problem about unzipping zip file and read only attribution file. i changed attribution to read-write and it works. but this time i have not parameterlocation .php
thanks
17 May 2019 14:01 #4 by babynus
If it is a first install, it is normal, this file is not deplyed.
It is created on configuration.
For first install, best is to give write rights to whole propjeqtor folder for php user (www-data on linux/debian like)
If it is migration, this happens if you dont' follow migration procedure : you must overwrite existing code with new one, so parametersLocation.php still exists.
17 May 2019 14:08 #5 by rvasighi
this is a first installation after installing my new operation system.
I changed all projeqtor folder from read only to read-write but i saw always the same message about access denied. in first configuration interface i must change anything? about user and password?
Actualy User :root
Pas: mysql
17 May 2019 14:11 #6 by babynus
Try without a password (this is default configuration of MySql on windows)
