ProjeQtOr free project management software - Project Template - Page 2 - ProjeQtOr
Project Template
11 Feb 2015 09:31 #7 by dem
Replied by dem on topic Project Template
Hi Babynus,
I found it! and modified the type. You were right of course, I didn't delete the TMP & ADM by default. I just closed them (this is the reason :) ).
So I tried the type ADM on one of my project. And the project doesn't appear in planning anymore.
What I would like to do is to simply assign activities to resources. And without going trough "real work allocation" or any actions from the resources. To get the resource planning generated.
Because as far I understood, OPE type, the resources need to go to "Real work allocation" assign days or hours (I believe is day=resource capacity, but why isn't it a tick box) on days of the current week. And once he validate the work, the resource will appear in "Resource planning". So I would like to skip this.
Is it possible?
Thank you really much for your patience.
Sincerely,
Dem
13 Feb 2015 13:03 #8 by babynus
Replied by babynus on topic Project Template
This is expected behavior.
AMD (administrative) and TMP (template) project are not suposed to be planned.
ADM projects are not planned. Only real work is entered(it is what they are done for).
You can use Activities screen to create assignment to resources, but :
1) you would have to affect resource to project before
2) you really don't need this because it is not how ADM projects work.
20 Feb 2015 10:02 #9 by dem
Is it possible to have the same behavior as "OPE", Except the fact when someone allocate some tasks to a resource, it is count as "real work allocation" automatically without any confirmation of the resources.
Thank you,
Sincerely,
Dem
20 Feb 2015 10:18 #10 by babynus
No, it's not possible.
This is completely opposit to ProjeQtOr philisophy.
20 Feb 2015 11:29 #11 by dem
Ho ok ok!
I don't want to disturb the philosophy :)
I though it was only a step in the entire process and that there is a solution to skip it. :silly:
So I will try to understand better how it is working. Because it still foggy for me.
Thank you again.
Wish you a great day and mostly weekend.
