ProjeQtOr free project management software - Pull down menu project / Menu deroulant projet - ProjeQtOr
18 Nov 2014 11:31 #1 by protion
There is a problem with the drop down menu does not work in standard mode, but operates in combo !!!!
Bonjour
Il y a un problème avec le menu déroulant, qui ne fonctionne pas en mode standard, mais fonctionne en mode liste déroulante !!!!
18 Nov 2014 16:50 #2 by babynus
Do you mean issue with Project Selector .
I could not reproduce such issue.
For me, Project Selector works fine, either in Filtering Select mode or in WBS presentation mode.
Could you please give more hint ?
=> what exactely is the issue ? What do you do and what happens ?
=> do you have any error on log file ?
=> do you have error on browser console ?
=> can you reproduce on Demo ?
18 Nov 2014 16:54 #3 by protion
No problem on the demo version, I'll make another up on my web server
Aucun probleme sur la version de demo, je vais refaire un up sur mon serveur Web
18 Nov 2014 16:57 #4 by babynus
Be sure to clean up browser cache. It may help.
