ProjeQtOr free project management software - Dealing with Sql - ProjeQtOr
Dealing with Sql
22 Sep 2014 14:34 #1 by mahesh.kute@bioanalytical.net
Hi I want to know
$lstWork=$work->getSqlElementsFromCriteria(null,false, $where, $order);
where I can update getSqlElementsFromCriteria function
I want to customize report for Reports==> Work==>Work-Monthly with all the resources assigned to that project.
Thanks in Advance
22 Sep 2014 16:26 - 22 Sep 2014 16:26 #2 by protion
Replied by protion on topic Dealing with Sql
hello
Information for all the report are in the report file.
Everything and find the right line to the modiffications (See Babynus).
Please note, you must know that it's change will crush during next update.
Bonjour
Pour information tout les rapport sont dans le dossier rapport.
Le tout et de trouver la bonne ligne pour faire les modiffications (Voir Babynus).
Attention, il vous faut savoir que c'est modification sera ecraser lors des prochaine mise a jour.
Last edit: 22 Sep 2014 16:26 by protion.
